Cesium Unreal enigne 5.4.4 problem
Hi im using Unreal engine 5.4.4, i downloaded a git hub version of the Cesium pack claiming it would be fixed of some issues in hopes to resolve a problem, i cannot load successfully photorealistic 3d tiles, if i refresh o troubleshoot it it ‘‘works’’ telling me that the tileset has loaded but it wont show up… im doing renders and maybe i used too much of the tiles working
Hi @Vittorio,
Sorry that you’re experiencing issues with the plugin. Could you share more detail with us so we can troubleshoot your issue?
  • What version of Cesium for Unreal are you using?
  • How are you streaming Google Photorealistic 3D Tiles? Are you streaming through Cesium ion? Or are you using your own Google API key?
  • Are you able to stream other data? For example, does Cesium World Terrain load successfully in your level?
Thank you!
Hi i’m using 5.4.0 Cesium with unreal engine 5.4.4, im trying to use Cesium Ion with the token, i’ve tried to stream other data but it does not work, is it possible that it wont load cause the scene is too packed and choses not to? it seems strange anyways because just last week i tried cause i upgraded unreal engine and everything worked fine then, i used it way too much for a day since i was editing the project helping my self with the 3d tiles but it was begging to disappear ( the tiles ) more often and then i reduced the quality level of the tiles and disappeared completely, since then i opened and closed the project many times and tried to make it work but nothing
