Google Photorealistic 3D Tiles not loading in Unreal Engine 5.5
Everything was working fine on the 5th of December the first and last time I used Cesium in Unreal. But upon opening my project the tiles wouldn’t appear.
I started a new Empty Level, added SunSky, turned DirectionalLight intensity down to 10 lux, added Blank 3D Tiles Tileset, made sure I was using an existing Token I made the last time, and added Google Photorealistic 3D Tiles. Still the tiles wouldn’t load.
I then deleted the token and made a new one, looked online for answers including deleting the Cesium Request Cache in appdata and restarting Unreal. I’ve even hit “RefreshTileset” and “TroubleshootTileset”. So far nothing has worked.
The Unreal Engine version I’m using is the newly released 5.5.0 version. The Cesium version is v2.11.0.
Hi @ConceptVerkuta, welcome to the community!
Sorry that you’re experiencing issues with the plugin, and thank you for including detail in your report.
Unfortunately I can’t reproduce this on my end, so I’m not sure what could be going wrong. Can you provide us with more information so we can troubleshoot?
  • Are you able to load other datasets? For example, can you successfully stream Cesium World Terrain?
  • Do you see any errors or warnings in the log?
It might also be worth downloading the Cesium for Unreal Samples and checking whether you can see the data in Level 12, 12_CesiumGoogleMapsTiles.
Thank you!
