Hello Cesium community !
I am currently working on a way to display a reference system of a satellite with only a czml file. I use the CZML writer to write my CZML. I found that the ‘vector agi’ object is still not yet implemented in cesium, so I am using polylines instead.
To represent my reference system, I draw three polylines, each polyline is created by offsetting a component in each direction (x,y,z) so I can have something like this :
So my packet containing my polyline object in my czml looks like this :
"id":"REFERENCE SYSTEM/Keplerian parameters: {a: 6928000.0; e: 0.0; i: 60.00000000000001; pa: 0.0; raan: 90.0; v: 90.0;}org.example.CZMLObjects.Polyline@27c6e487",
"name":"Reference system of : Satellite",
"availability":"2022-01-17T12:00:00Z/2022-01-18T12:00:00Z",
"position":{
"reference":"Keplerian parameters: {a: 6928000.0; e: 0.0; i: 60.00000000000001; pa: 0.0; raan: 90.0; v: 90.0;}#position"
"polyline":{
"width":10,
"arcType":"NONE",
"show":true,
"material":{
"solidColor":{
"color":{
"rgba":[
255,10,10,255
"positions":{
"cartesian":[
-1557190.827699542,-3108469.9818882565,5992474.872523712,
-1547190.827699542,-3108469.9818882565,5992474.872523712
"referenceFrame":"INERTIAL"
"show":{
"interval":"2022-01-17T12:00:00Z/2022-01-17T12:01:00Z",
"boolean":true
Now, as you can see, I use references to put my polyline in a given position (here it’s the id of my satellite where I added #position to use the position). But is seems like the polyline object is not following at all the satellite :
Here is the CZML file that I use
If you need more precisions do not hesitate,
Thank you,
JL
