Hello,wWhy i cant render the geo in movie render queue? The top img is render image from movie render queue,and the bottom is the view in UE5
There have been some ongoing issues with rendering 3D Tiles in the movie render queue. Your issue may be related to the problem described here: Frustrum culling does not account for different aspect ratios (In Sequencer) · Issue #680 · CesiumGS/cesium-unreal · GitHub.
One thing I can suggest is to make sure the cameras you want to use while rendering are all added under the CesiumCameraManager. But otherwise, we’ll have to do more testing to figure out where the problem is coming from.
I fix it up, it need to increase samples in the render setting
