Hi Gabby,
Thanks for the link.
I’m doing this to bypass the ScreenSpaceEvents:
let pinchEnded = true;
const touchInfo: Array<{
touchId: number;
startPosition: { x: number; y: number };
const ngTouchstartHandler = renderer.listen(
this.mainMapViewer.canvas,
“touchstart”,
e => {
pinchEnded = e.touches.length <= 1;
// Capture touch info for every changed touch point on the screen
for (let i = 0; i < e.changedTouches.length; i++) {
const changedTouch = e.changedTouches.item(i);
touchInfo.push({
startPosition: {
x: changedTouch.clientX,
y: changedTouch.clientY
touchId: changedTouch.identifier
const ngTouchendHandler = renderer.listen(
“touchend”,
e => {
// If all touches have been removed from the screen…
if (e.touches.length === 0) {
// …then check to see how far the changed touches had been moved before being removed from the screen
const startPosition = _.find(
touchInfo,
x => x.touchId === changedTouch.identifier
).startPosition;
const endPosition = {
const xDiff = startPosition.x - endPosition.x;
const yDiff = startPosition.y - endPosition.y;
const totalPixels = Math.sqrt(xDiff * xDiff + yDiff * yDiff);
// If the touches have moved a distance less than the tolerance then a LEFT_CLICK event will be fired
if (totalPixels < this.cesiumClickPixelTolerance) {
// So set this variable to false to prevent stuff being done in the LEFT_CLICK handler
pinchEnded = false;
cesiumClickHandler.setInputAction(click => {
if (pinchEnded) {
// Do stuff...
pinchEnded = pinchEnded || true;
It works pretty well.
Harry
