Unreal Engine 5.7 and Cesium "Maximum Cached Bytes"
Hello.
I ahve an issue using Cesium inside Unreal engine.
I suspect Cesium World Terrain with Cesium OSM Buildings cause my project have performance spikes (laggs in certain areas). I am not sure but i am testing it. To optimise my project what i want to test for pixel streaming.
Currewntly inside my unreal engine 5.7
Chat GP recomends me this and wanted to test it out. And tried to change Maximum Chached Bytes inside Cesium plugin in Unreal engine. But number automatically reverts back to 268435456
How to change that?
Things that often trigger the VRAM warning in Cesium projects
:one: Tiles loading too quickly
Limit loading bursts.
In your Cesium3DTileset actor:
Maximum Simultaneous Tile Loads = 10
Sometimes the default is 20–50, which causes spikes.
:two: Cache too small
Increase:
Try:
4000000000  (4 GB)
or even 6 GB if you have RAM available.
:three: Camera moving too fast
Fast camera movement in Cesium scenes loads many terrain + building tiles simultaneously.
This can temporarily explode memory requests.
Hello @ISUther,
That’s rather strange. I’m not encountering that on my end with UE 5.7.3, c4u 5.7.0
When does the value reset? Any other behaviors you can share that might be causing this?
Are you using Nanite asset with RT Shadows and the CVar r.RayTracing.Nanite.Mode=1 in your scene ?
I had these spikes with Cesium and Nanite meshes, but the lags were not related to Cesium even if Unreal insight was showing this.
