Gday all,
So I'm trying to work out if I'm doing something wrong....
I have an entity (essentially a point), and Im successfully adding an ellipse to the entity, when I do so the map automatically updates to reflect the added ellipse.
However when I try to remove the ellipse using entity.removeProperty('_ellipse')
the map does not update...
Is this a bug or is there a way to force the redraw of the entity?
Rowan
Hello Rowan,
This should work for removing your ellipse:
entity.ellipse = undefined;
Hannah
Thanks Hannah, that did the job!
I wonder if removeProperty() should set the variable to undefined? I'd be happy to put in a pull request if you thought it was worthwhile...
I think removeProperty is meant for removing a custom property added with addProperty. An ellipse is a default property so that’s why it didn’t work.
Hannah
