I am working with CZML source data. I would like to update the InfoBox ‘description’ with continually evolving information and images from a server. I have picked and pulled at some forum threads but have not found how to grab hold of the czml ‘description’ data and have it display the updated description on each InfoBox update.
As always in appreciation of any suggestions… Erik
For sandcastling, upon selecting “Boston” I’d like to see “Boston’s current temperature is…” instead of “Boston is a city…”.
var scene = viewer.scene;
var czml =
[{“id” : “document”,
“version” : “1.0”
},{“id” : “Boston”,
“label”:{“text”:“Boston”},
“position”:{“cartographicDegrees”:[-71.0589,42.3601,0]},
“description”:“Boston is a city…”,
},{“id” : “New York City”,
“label”:{“text”:“New York”},
“description”:“New York is a city…”,
“position”:{“cartographicDegrees”:[-74.0059,40.7127,0]},
var promise = Cesium.CzmlDataSource.load(czml);
promise.then(function(dataSource) {
function pickEntity(viewer, windowPosition) {
var picked = viewer.scene.pick(windowPosition);
if (defined(picked)) {
var id = Cesium.defaultValue(picked.id, picked.primitive.id);
… ADD BOSTON DESCRIPTION UPDATE (‘description’ : “Boston’s current temperature is…”
if (id instanceof Cesium.Entity) {
//------ create CZML ------
var czml =
“version” : “1.0”
},{“id” : “Boston”,
//------ Get the array of entities
//------ Loop entities
for (var i = 0; i < entities.length; i++) {
var entity = entities[i];
var name = entity.label;
entity.label.translucencyByDistance = new Cesium.NearFarScalar(100000,1.0,500000,0.0);
}).otherwise(function(error){
//------ Display error
window.alert(error);
//------ Use SSEH to update to current description
var handler = new Cesium.ScreenSpaceEventHandler(scene.canvas);
handler.setInputAction(function(click) {
var pickedObject = scene.pick(click.position);
if (Cesium.defined(pickedObject)) {
pickedObject.id.description = ‘The current temperature is…’;
