I am trying to update the radius of a circle using ellipse graphics, but if I edit just the semiMinor/MajorAxis doesn't induce a circle update, the same way that changing the position of the circle does. Is there a "dirty" bit or something I can set so that the circle will update?
entity.ellipse.semiMinorAxis._value = radius;
(is there something else I can set so that I can trigger an image update?)
I am using two billboards to update the position of the circle, as well as the radius. A change in position triggers an update in real time, but a change in axis doe not.
The Cesium API makes an assumption that all entities are static by default to speed up performance. So using a CallbackProperty (https://cesiumjs.org/Cesium/Build/Documentation/CallbackProperty.html) for any property that needs to change over time is the intended way of doing this.
You can see that an Ellipse is marked as dynamic if any of its properties are a callback property:
