I upgraded from Cesium 1.59.0 to Cesium 1.63.0. All was working fine prior to the upgrade with 1.59.0. However, now after the upgrade when I try to add a primitive to I receive the below RuntimeError…
Vertex texture fetch support is required to render primitives with per-instance attributes. The maximum number of vertex texture image units must be greater than zero.
I suspect this issue is caused by us perhaps explicitly importing the ES6 modules? Not really sure. In the file the error is occurring in our imports look like…
const {
Billboard: CesiumBillboard,
BillboardCollection: CesiumBillboardCollection,
BoundingSphere: CesiumBoundingSphere,
Cartesian2: CesiumCartesian2,
Cartesian3: CesiumCartesian3,
Cartographic: CesiumCartographic,
CircleGeometry: CesiumCircleGeometry,
CircleOutlineGeometry: CesiumCircleOutlineGeometry,
Color: CesiumColor,
ColorGeometryInstanceAttributes: CesiumColorGeometryInstanceAttribute,
defined: CesiumDefined,
destroyObject: CesiumDestroyObject,
DeveloperError: CesiumDeveloperError,
Ellipsoid: CesiumEllispoid,
EllipsoidGeometry: CesiumEllipsoidGeometry,
EllipsoidOutlineGeometry: CesiumEllipsoidOutlineGeometry,
EllipsoidGeodesic: CesiumEllipsoidGeodesic,
EllipsoidSurfaceAppearance: CesiumEllipsoidSurfaceAppearance,
FeatureDetection: CesiumFeatureDetection,
GeometryInstance: CesiumGeometryInstance,
HorizontalOrigin: CesiumHorizontalOrigin,
LabelCollection: CesiumLabelCollection,
Math: CesiumMath,
Material: CesiumMaterial,
PerInstanceColorAppearance: CesiumPerInstanceColorAppearance,
PolygonGeometry: CesiumPolygonGeometry,
PolygonOutlineGeometry: CesiumPolygonOutlineGeometry,
PolylineMaterialAppearance: CesiumPolylineMaterialAppearance,
PolylineGeometry: CesiumPolylineGeometry,
Primitive: CesiumPrimitive,
Rectangle: CesiumRectangle,
RectangleGeometry: CesiumRectangleGeometry,
RectangleOutlineGeometry: CesiumRectangleOutlineGeometry,
ScreenSpaceEventHandler: CesiumScreenSpaceEventHandler,
ScreenSpaceEventType: CesiumScreenSpaceEventType,
VerticalOrigin: CesiumVerticalOrigin
} = require(‘cesium’);
How can I enable Vertex texture fetch support? Any help would be great!
