Hi all,
I'm trying to feed ArcGIS LERCs to TerrainProvider. I've followed the old ArcGisImageServerTerrainProvider logic as reference and this thread:
https://groups.google.com/forum/#!msg/cesium-dev/zhJgvO4U3Vk/A3yvKnQRMA8J
The LERC part is easy; After decoding the LERC format I have a 257x257 terrain tile containing the altitudes in MSL (geoid, not ellipsoid).
Following ArcGisImageServerTerrainProvider logic, I've tried to feed a downscaled image to HeightmapTerrainData, but as far as I can see there's no terrain data at all in my scene.
Cesium does call requestTileGeometry for the whole pyramid (from zoom 0 to the max zoom defined by childTileMask - I've put logging to verify this).
I'm not sure how to progress from here. Is this the right way to load terrain data to Cesium? Is there a better way?
Is there reference code for something like this?
This is the code that actually loads the terrain data:
// Load LERC
let lerc = response.data;
let image = Lerc.decode(lerc);
let imageData = image.pixels[0];
// Limit pyramid depth
let childrenAvailable = 15;
if (level >= 13) {
childrenAvailable = 0;
// Load the LERC data into a heightmap buffer
let terrainBuffer = this.getImagePixels(imageData, image.width, image.height);
let result = new Cesium.HeightmapTerrainData({
buffer : terrainBuffer,
width : 65,
height : 65,
childTileMask : childrenAvailable, // all children present
structure : this._terrainDataStructure
console.log('LERC Loaded [Level: ' + level + ' X: ' + x + ' Y: ' + y);
return result;
Chrome Version 72.0.3626.121
Windows 10
Cesium 1.54
Thanks!
Nitay
