I am using cesium’s PolylineVolumeGeometry to load the tap water pipeline. Because of the huge number, I used GeometryInstance. I loaded more than 30,000 pipes, and I found a strange phenomenon. When all the pipes appear in the camera, the fps is about 60 frames, but when the camera gradually approaches these pipes (some of the pipes are not in the camera ), The fps starts to drop, and the final fps is small and 10, the webpage becomes very stuttered.
In theory, rendering more pipelines requires greater overhead. But it seems the other way around.
Below is the test code and related screenshots.
Who helped me see what happened, thanks.
var viewer = new Cesium.Viewer(‘cesiumContainer’,{scene3DOnly :true});
viewer.scene.debugShowFramesPerSecond = true;
viewer.scene.globe.depthTestAgainstTerrain = true;
var instanceArray = ;
var i = 0;
while(i < 30000) {
var la = 41.0 + i*0.001;
var volume = new Cesium.PolylineVolumeGeometry({
vertexFormat: Cesium.VertexFormat.POSITION_AND_NORMAL,
polylinePositions: Cesium.Cartesian3.fromDegreesArray([
-72.0, 40.0,
-72.0, la
shapePositions: [new Cesium.Cartesian2(-5000, -2000),
new Cesium.Cartesian2(2000, -6000),
new Cesium.Cartesian2(5000, -2000),
new Cesium.Cartesian2(5000, 5000),
new Cesium.Cartesian2(-5000, 5000)]
instanceArray.push(new Cesium.GeometryInstance({
geometry : volume,
attributes : {
color : Cesium.ColorGeometryInstanceAttribute.fromColor(Cesium.Color.fromRandom())
i++;
viewer.scene.primitives.add(new Cesium.Primitive({
geometryInstances: instanceArray,
appearance: new Cesium.PerInstanceColorAppearance({translucent: false}),
vertexCacheOptimize: true,
interleave : true,
cull:false,
allowPicking: false,
compressVertices: false
