UV rendering exception
The example code is as follows, rendering a surface using texture coordinates. The texture coordinates of the point in the upper right corner cannot be assigned, I don’t understand why it doesn’t work:
Just to have the connection: This was also opened as an issue UV rendering exception · Issue #12408 · CesiumGS/cesium · GitHub
