I ran into the same problem as the post Texture coordinates problem.
I expected to get 4 repeated images (2X2), but only got 2. The full code example which can run on Sandcastle as following.
Further, I tested GLSL and found that the vertex shader is wrong with the UV coordinates: The U direction is right but the V direction is wrong (V direction coordinate seem to automatically take decimal parts, ranging from 0 to 1). I can provide the GLSL code if you think it is necessary.
I am doing this research in the hope of being able to map the triangular irregular network as I want. Thanks.
var mypositions = Cesium.Cartesian3.fromDegreesArray([-110, 20, -100, 20, -100, 30, -110, 30]);
var numPositions = mypositions.length;
var pos = new Float64Array(numPositions * 3);
for (var i = 0; i < numPositions; ++i) {
pos[i * 3] = mypositions[i].x;
pos[i * 3 + 1] = mypositions[i].y;
pos[i * 3 + 2] = mypositions[i].z;
var uvs = [0, 0, 1, 0, 1, 1, 0, 1];
var indexs = new Uint16Array([0, 1, 2, 2, 3, 0]);
var geometry = new Cesium.Geometry({
attributes: {
position: new Cesium.GeometryAttribute({
componentDatatype: Cesium.ComponentDatatype.DOUBLE,
componentsPerAttribute: 3,
values: pos
st: new Cesium.GeometryAttribute({
componentDatatype: Cesium.ComponentDatatype.FLOAT,
componentsPerAttribute: 2,
values: uvs
indices : indexs,
primitiveType: Cesium.PrimitiveType.TRIANGLES,
boundingSphere: Cesium.BoundingSphere.fromVertices(pos)
var myInstance = new Cesium.GeometryInstance({
geometry: geometry,
viewer.scene.primitives.add(new Cesium.Primitive({
geometryInstances: myInstance,
appearance: new Cesium.MaterialAppearance({
material : new Cesium.Material({
fabric : {
type : 'Image',
uniforms : {
image : "../images/Cesium_Logo_Color.jpg"
asynchronous: false,
You can change line 10 as follow to test
var uvs = [0, 0, 2, 0, 2, 2, 0, 2];
Draw two times in U direction but one time in V direction.
or
var uvs = [0, 0, 2.5, 0, 2.5, 2.5, 0, 2.5];
Draw 2.5 times in U direction but half image in V direction.
