Hello!
I have some visual problem when use manually calculated texture coordinates outside interval [0, 1].
By some reason I don’t use “Image” material with repeat uniform.
I create manually wall geometry with 4 points and 2 triangles and self calculate texture coordinates outside interval [0, 1] (use Cesium 1.91 release).
Code for position geometry attribute is:
var geoLine = new Cesium.EllipsoidGeodesic(
Cesium.Cartographic.fromDegrees(45, 45, 0),
Cesium.Cartographic.fromDegrees(46, 46, 0),
var height = 5;
var distance = 50;
var gp0 = geoLine.interpolateUsingSurfaceDistance(0);
var gp1 = new Cesium.Cartographic(gp0.longitude, gp0.latitude, height);
var gp2 = geoLine.interpolateUsingSurfaceDistance(distance);
var gp3 = new Cesium.Cartographic(gp2.longitude, gp2.latitude, height);
var geocentricPositions = [Cesium.Cartographic.toCartesian(gp0),Cesium.Cartographic.toCartesian(gp1),Cesium.Cartographic.toCartesian(gp2),Cesium.Cartographic.toCartesian(gp3)];
var valuesPosition = new Float64Array(geocentricPositions.length * 3);
for (var i = 0; i < geocentricPositions.length; i++) {
valuesPosition[3 * i] = geocentricPositions[i].x;
valuesPosition[3 * i + 1] = geocentricPositions[i].y;
valuesPosition[3 * i + 2] = geocentricPositions[i].z;
var positionAtt = new Cesium.GeometryAttribute({
componentDatatype: Cesium.ComponentDatatype.DOUBLE,
componentsPerAttribute: 3,
values: valuesPosition
Code for texture coordinate geometry attribute is:
var stHeight = 2.2;
var stWidth = 20.1;
// var stHeight = 1.0;
// var stWidth = 1.0;
var stAtt = new Cesium.GeometryAttribute({
componentDatatype: Cesium.ComponentDatatype.FLOAT,
componentsPerAttribute: 2,
values: new Float32Array([
0.0, 0.0,
0.0, stHeight,
stWidth, 0.0,
stWidth, stHeight
Code for create geometry is:
var boundingSphere = Cesium.BoundingSphere.fromPoints(geocentricPositions);
var geometry = new Cesium.Geometry({
attributes: {
position: positionAtt,
st: stAtt
primitiveType: Cesium.PrimitiveType.TRIANGLES,
indices: new Uint16Array([
0, 3, 1,
2, 3, 0
boundingSphere: boundingSphere,
geometry = Cesium.GeometryPipeline.computeNormal(geometry);
geometry = Cesium.GeometryPipeline.compressVertices(geometry);
Code fore use Cesium.Material like this:
var material = new Cesium.Material({
fabric: {
type: “Image”,
uniforms: {
image: “MyScripts/mesh.png”,
repeat: new Cesium.Cartesian2(1.0, 1.0),
And code for create primitive and use it:
var primitive = new Cesium.Primitive({
asynchronous: false,
geometryInstances: new Cesium.GeometryInstance({
geometry: geometry,
appearance: new Cesium.MaterialAppearance({
translucent: false,
materialSupport: Cesium.MaterialAppearance.MaterialSupport.TEXTURED,
material: material,
var labels = new Cesium.LabelCollection();
labels.add({ position: geocentricPositions[0], text: “№0” });
labels.add({ position: geocentricPositions[1], text: “№1” });
labels.add({ position: geocentricPositions[2], text: “№2” });
labels.add({ position: geocentricPositions[3], text: “№3” });
viewer.scene.primitives.add(primitive);
viewer.scene.primitives.add(labels);
// fly to primitive
viewer.scene.camera.flyToBoundingSphere(boundingSphere);
viewer.scene.requestRender(); -
I use self image *.png for texture (32 by 32 pixels)
Result (correct) view with Cesium “Image” for parameters (
var stHeightandvar stWidthuse as parameter for texture coordinates):
stHeight = 1.0;stWidth = 1.0;- fabric “Image” uniform is
repeat: new Cesium.Cartesian2(20.1, 2.3).
This is correct view!
- Result view with Cesium “Image” for parameters (no repeat, self texture coordinates,
stHeight = 2.5;stWidth = 20.1;- fabric “Image” uniform is
repeat: new Cesium.Cartesian2(1.0, 1.0).
Correct count repeat by width, but height has some visual error.
- I create self material “ImageTest” by this code:
if (!Cesium.defined(Cesium.Material.ImageTestType)) {
Cesium.Material.ImageTestType = “ImageTest”;
Cesium.Material._materialCache.addMaterial(Cesium.Material.ImageTestType, {
fabric: {
type: Cesium.Material.ImageTestType,
uniforms: {
image: Cesium.Material.DefaultImageId,
color: new Cesium.Color(1.0, 1.0, 1.0, 1.0),
components: {
// diffuse: “texture2D(image, materialInput.st).rgb * color.rgb”,
// alpha: “texture2D(image, materialInput.st).a * color.a”,
diffuse: “texture2D(image, fract(materialInput.st)).rgb * color.rgb”,
alpha: “texture2D(image, fract(materialInput.st)).a * color.a”,
translucent: function(material) {
return material.uniforms.color.alpha < 1.0;
And try use different parameters forcomponents:diffuseandalpha. Usetexture2D(image, materialInput.st)withoutfractand with ittexture2D(image, fract(materialInput.st)). - Result view with my"ImageTest" for parameters (self texture coordinates and fract):
stHeight = 2.5;stWidth = 20.1;texture2D(image, fract(materialInput.st)).
- Result view with my"ImageTest" for parameters (self texture coordinates without fract):
stHeight = 2.5;stWidth = 20.1;texture2D(image, materialInput.st).
Then I try use parameter for texture Cesium.TextureWrap.REPEAT because
by default fore Cesium Material use Cesium.TextureWrap.CLAMP_TO_EDGE.
I patch Material.js like this (add options for wrapS and wrapT) and build Cesium:
this._magnificationFilter = defaultValue(
options.magnificationFilter,
TextureMagnificationFilter.LINEAR
// !!! append use new parameters wrapS and wrapT
this._wrapS = defaultValue(
options.wrapS,
this._wrapT = defaultValue(
options.wrapT,
const sampler = new Sampler({
minificationFilter: this._minificationFilter,
magnificationFilter: this._magnificationFilter,
//!!! append using wrapS and wrapT
wrapS: this._wrapS,
wrapT: this._wrapT,
// and for all operation “new Sampler(…)” in code “Material.js”
I append options (wrapS and wrapT) for Cesium.Material but this not solve my problem (I have patch code but don’t print it).
I could not get result like Cesium “Image” and repeat uniform when i using self “ImageTest” and texture coordinates outside interval [0, 1]. What is incorrect in using Material and st coordinates.
Create Sandcastle examples (modified example, with rectangle wall height and width by 50 meters)
- “Example 1-0” - use repeate, st inside [0,1], fabricType “Image”.
- “Example 1-1” - st inside [0,1], fabricType “ImageTest”.
- “Example 2-0” - st outside [0,1] (s=t=5.1), fabricType “Image”, no repeate.
- “Example 2-1” - st outside [0,1] (s=t=5.1), fabricType “ImageTest”, repeate not use.
- “Example 2-2” - st outside [0,1] (s=t=5.1), fabricType “ImageTestFract”, repeate not use.
- “Example 3-0” - st outside [0,1] (s=t=5.7), fabricType “Image”.
- “Example 3-1” - st outside [0,1] (s=t=5.7), fabricType “ImageTest”, repeate not use.
- “Example 3-2” - st outside [0,1] (s=t=5.7), fabricType “ImageTestFract”, repeate not use.
