After updating from v1.4 to v1.5 my flight simulation site no longer runs in Chrome.
From Chrome:
Uncaught TypeError: Cannot read property ‘viewModel’ of undefined Cesium.js:422
V._onTick Cesium.js:378
r.raiseEvent Cesium.js:384
l.tick Cesium.js:419
P.render Cesium.js:422 V.render
In Firefox it runs OK but with lots of warnings:
mutating the [[Prototype]] of an object will cause your code to run very slowly; instead create the object with the correct initial [[Prototype]] value using Object.create Cesium.js:414
Error: WebGL: Disallowing antialiased backbuffers due to blacklisting. Cesium.js:404
Error: WebGL: A texture is going to be rendered as if it were black, as per the OpenGL ES 2.0.24 spec section 3.8.2, because it is a 2D texture, with a minification filter requiring a mipmap, and is not mipmap complete (as defined in section 3.7.10). Cesium.js:396
Error: WebGL: A texture is going to be rendered as if it were black, as per the OpenGL ES 2.0.24 spec section 3.8.2, because it is a cube map texture, with a minification filter requiring a mipmap, and is not mipmap cube complete (as defined in section 3.7.10). Cesium.js:405
Error: WebGL: No further warnings will be reported for this WebGL context (already reported 32 warnings) Cesium.js:396
Having the same issue.
Tried incognito tab and cleared browser cache.
Still seeing the error.
Hi Dennis,
Are you using the latest version of Chrome? Does the empty Cesium Viewer for 1.5 work for you: https://cesiumjs.org/Cesium/Build/Apps/CesiumViewer/index.html
Can you add the unminified Cesium.js to your app and provide a call stack?
Your flight simulation sounds cool. Can you share a link to it?
Patrick
Hi Patrick,
Yes I am using the latest of Chrome.
The empty cesium Viewer works for me.
The following link is making use of 1.5 and the unminified Cesium.js
http://19.mcyclingthealps.appspot.com/cesium15/cesium.html?xStart=45.30187999999999&yStart=6.95305&xEnd=45.29968&yEnd=6.93618&cat=HC&from=Dennis&pass=ColdeMadeleine
It crashes on line 142353 of the unminified file.
The following link is making use of 1.4 and the normal cesium.js and here it works
http://19.mcyclingthealps.appspot.com/cesium/cesium.html?xStart=45.30187999999999&yStart=6.95305&xEnd=45.29968&yEnd=6.93618&cat=HC&from=Dennis&pass=ColdeMadeleine
The flight simulation is from Matt.
Dennis
Dennis - perfect, thanks for the link! I submitted issued #2379. We’ll look at it soon.
Matt - would still love to see your flight simulation?
Patrick
This looks like a definite bug. Can you try setting selectionIndicator to true in the options parameter where you construct the viewer and see if it fixes the problem? You shouldn’t have to do that; but it should work around the current crash.
Hi Mattew,
Setting the selectionIndicator to true fixes the problem.
The link above now works.
Dennis
Yes that fixes the problem. Thanks!
Thanks guys. We’ve fixed the bug in master and it will go out with the next release: https://github.com/AnalyticalGraphicsInc/cesium/pull/2380
