Hi Cesium folks,
Is there any known way to view entities or primitives that normally would be hidden from view because the globe is in the way?
I’ve attached a file illustrating the issue. Sometimes I want to show the equivalent of the “whole world”, in order to all of the points where there is data, even if they are “behind” the globe.
If the data is small enough, you can just move the camera to the right spot and you’ll be able to view them all. But in the attached case, there is no single camera position that will capture all the buried treasure entities. At least one will always be blocked by the globe.
