Hi, Hannah…
I’m running this in Cesium v1.19 Sandcastle:
var czmlDocument = [{
“id” : “document”,
“name” : “CZML Point”,
“version” : “1.0”
var czml = [
“id” : “point1”,
“name”: “point”,
“position” : {
“cartesian” : [1864828.93,3364932.93,5070208.06]
“label” : {
“fillColor” : {
“rgba” : [255, 255, 255, 255]
“font” : “12pt Lucida Console”,
“horizontalOrigin” : “LEFT”,
“pixelOffset” : {
“cartesian2” : [8, 0]
“style” : “FILL”,
“text” : “point1”,
“showBackground” : true,
“backgroundColor” : {
“rgba” : [112, 89, 57, 200]
“point”: {
“color”: {
“rgba”: [255, 255, 255, 255]
“outlineColor”: {
“rgba”: [255, 0, 0, 255]
“outlineWidth” : 4,
“pixelSize”: 20
var czmlDelete = [
“id”:“point1”,
“delete”:true
var inView = function(_position, _viewer) {
try {
var camera = _viewer.scene.camera;
var frustum = camera.frustum;
var cullingVolume = frustum.computeCullingVolume(camera.position, camera.direction, camera.up);
return cullingVolume.computeVisibility(new Cesium.BoundingSphere(_position, 0.0)) === Cesium.Intersect.INSIDE;
} catch (e) {
console.log(e);
return false;
var viewRectangle = function(_viewer) {
var ellipsoid = _viewer.scene.globe.ellipsoid;
return _viewer.scene.camera.computeViewRectangle(ellipsoid);
var dataSource = new Cesium.CzmlDataSource(‘test’);
dataSource.load(czmlDocument);
Sandcastle.addToolbarButton(‘Process Point’, function() {
dataSource.process(czml).then(function(ds) {
var rect = viewRectangle(viewer);
console.log(‘Entities (processed): ’ + ds.entities.values.length + ’ viewRect: [w:’ + rect.west + ’ s:’ + rect.south + ’ e:’ + rect.east + ’ n:’ + rect.north + ‘]’);
for(var i = 0; i < ds.entities.values.length; i++) {
var e = ds.entities.values[i];
var position = e.position.getValue(viewer.clock.currentTime);
var screen = Cesium.SceneTransforms.wgs84ToWindowCoordinates(viewer.scene, position);
console.log(e.id + ’ ’ + position + ’ screen:’ + screen + ', visible: ’ + inView(position, viewer));
Sandcastle.addToolbarButton(‘Delete Point’, function() {
dataSource.process(czmlDelete).then(function(ds) {
console.log('Entities (processed): ’ + ds.entities.values.length);
Initially, I wanted to see screen position of the point from the console. Seems to work great. Then, I ‘Delete Point’ and rotated the Earth to the opposite side so that the point would not be visible when I ‘Process Point’ – after processing the point, I still get a screen position even when the point is behind the Earth. Is this the position of the point on the screen if it were to be projected to the front?
I’m also logging to the console the view rectangle as you suggested and I’m seeing that the coordinates are the same every time I hit ‘Process Point’ even after zooming in and out and changing the view.
I’ve also added an inView function that doesn’t seem to be behaving as expected because the screen position is always returning a value that is within the view.
