is it possible to use Cesium for Unreal for a Virtual Visit inside a building’s 3D model without using the cesium world ?
The model has been made via photogrammetry with metashape.
I only need to stay inside the building 3D model.
thanks
thanks
Hi @cyrilp, welcome to the community.
You can definitely use Cesium for Unreal in that way. If your model has been uploaded to ion, you can import it the same way you do other datasets following this tutorial - Adding Datasets – Cesium
The world terrain is not necessary for this to work, so you can just skip that entirely.
Thanks i’ll have a look !
