- Can i add the project of unreal in cesium so that i could view them in the web.
Hi @jhsyzxy
If I understand your question correctly, you are asking whether Cesium for Unreal can be used with CesiumJS on the web?
The answer to this is that CesiumJS and Cesium for Unreal are complimentary runtime visualization engines. CesiumJS is a custom-built high-precision web-based geospatial engine, while Cesium for Unreal adds functionality to Unreal Engine.
Both CesiumJS and Cesium for Unreal are based on open standard and can be used to visualize data streaming as open standard and APIs like 3D Tiles.
Regards
Shehzan
Thanks a lot, that is what i want to ask.But I am confused with the third paragraph. What you mean is that both cesium and cesium for unreal can use the data such as 3D Tiles, or we can transform the data from cesium and cesium for unreal to 3D Tiles in order to use it somewhere else.
Yes, and other data in supported open standards.
This would be something you can do on Cesium ion.
ok,thanks a lot
