"WebMapServiceImageryProvider" The Resource is already being fetched
When I load WebMapServiceImageryProvider, I call the pickFeatures method and I get the "The Resource is already being fetched" error.
Later, I found that even if I didn't call the pickFeatures method and clicked on the globe multiple times, the "The Resource is already being fetched" error would appear.
var world = new Cesium.WebMapServiceImageryProvider({
   url: ‘http://gisserver.tianditu.com/TDTService/gdp/2014/wms’,
   layers: ‘060101’,
   tileWidth: 256,
   tileHeight: 256,
   minimumLevel: 0,
   maximumLevel: 20,
var imageProvider = viewer.imageryLayers.addImageryProvider(world);
I need to get the data of the WMS ImageryLayerFeatureInfo at the current mouse click position and display it in a polygon.
Version 1.51
Windows64
Google Chrome
I can’t access the URL in your code, so I can’t test that. Are you able to reproduce this issue here?
Can you show how you’re using pickFeatures? Make sure you’re calling it after the ready boolean is true:
https://cesiumjs.org/Cesium/Build/Documentation/WebMapServiceImageryProvider.html#ready
