I try to understand what is cartographic? and I can not found enough explain, can someone explain it why we use it and what for we use?
I know Cartesian3 is mean 3 dimensional x,y,z
lng,lat(WGS84) for locations also we can change it to radians
And we can convert cartesian3 to locations or vice versa but I did not understand cartographic.
This is the Cartographic coordinate; latitude (or projected northing), longitude (or projected easting), height (optional). Latitude and longitude can be expressed in a myriad of ways, but more commonly these days as degrees (because the GPS standard use WGS84), but radian calculations are sometimes faster, so still a much used option.
Is your question around coordinates in general, or just what Cesium call Cartographic?
Cheers,
Alex
Thank you for answer Alex its very enough for me.
Can you explain what cesium call Cartograohic too if there is a difference ?
Cheers,
Hüseyin
Cartographic is what Cesium calls a lat,long,height coordinate (sometimes called a geodesic or geodedic coordinate).
Cheers,
Alex
