When I loaded the terrain data from local nginx server, the earth will display a black area,just like image below。
When I remove the terrain, there is no such problem。
I tryed version 108 and 95。
Will reproduce the problem
looks like some of the geometry/texture data are not properly loaded, will you check the browser’s network panel?
thanks all, I find the answer.
When I transfer data to terrain, I can select trangle algorithm,I change the algorithm, the problem seems solved!
thanks again!
