Compute Configuration
| cpu | Memory | disk | gpu |
| 8*i7-7700 360Ghz | 16GB | 250GB | NVIDIA GeForce GT 730 |
browser:Chrome newest
Two kinds of errors
First kind
pic
Text
DeveloperError: Expected width to be greater than 0, actual value was 0
Error
at new DeveloperError (http://192.168.100.95:18030/test/static/libs/CesiumUnminified/Cesium.js:83:13)
at Function.Check.typeOf.number.greaterThan (http://192.168.100.95:18030/test/static/libs/CesiumUnminified/Cesium.js:260:13)
at new Texture (http://192.168.100.95:18030/test/static/libs/CesiumUnminified/Cesium.js:98320:25)
at createTextures$1 (http://192.168.100.95:18030/test/static/libs/CesiumUnminified/Cesium.js:271775:37)
at updateFramebuffers$4 (http://192.168.100.95:18030/test/static/libs/CesiumUnminified/Cesium.js:271868:7)
at GlobeDepth.update (http://192.168.100.95:18030/test/static/libs/CesiumUnminified/Cesium.js:272071:5)
at updateAndClearFramebuffers (http://192.168.100.95:18030/test/static/libs/CesiumUnminified/Cesium.js:304338:23)
at executeCommandsInViewport (http://192.168.100.95:18030/test/static/libs/CesiumUnminified/Cesium.js:304072:9)
at Scene.updateAndExecuteCommands (http://192.168.100.95:18030/test/static/libs/CesiumUnminified/Cesium.js:303808:7)
at render (http://192.168.100.95:18030/starview/static/libs/CesiumUnminified/Cesium.js:304692:11
Second King
pic
text
Cesium.js:1 [Cesium WebGL] Fragment shader compile log:
createAndLinkProgram @ Cesium.js:1
Cesium.js:1 WebGL: INVALID_OPERATION: getTranslatedShaderSource: attempt to use a deleted object
Cesium.js:1 [Cesium WebGL] Fragment shader translation failed.
Cesium.js:1 An error occurred while rendering. Rendering has stopped.
RuntimeError: Fragment shader failed to compile. Compile log:
Error
at new RuntimeError (http://192.168.100.95:18030/test/static/libs/Cesium/Cesium.js:1:40928)
at createAndLinkProgram (http://192.168.100.95:18030/test/static/libs/Cesium/Cesium.js:1:949048)
at reinitialize (http://192.168.100.95:18030/test/static/libs/Cesium/Cesium.js:1:951769)
at initialize$b (http://192.168.100.95:18030/test/static/libs/Cesium/Cesium.js:1:951701)
at ShaderProgram._bind (http://192.168.100.95:18030/test/static/libs/Cesium/Cesium.js:1:955514)
at beginDraw (http://192.168.100.95:18030/test/static/libs/Cesium/Cesium.js:1:2544159)
at Context.draw (http://192.168.100.95:18030/test/static/libs/Cesium/Cesium.js:1:2545708)
at DrawCommand.execute (http://192.168.100.95:18030/test/static/libs/Cesium/Cesium.js:1:912887)
at executeCommand (http://192.168.100.95:18030/test/static/libs/Cesium/Cesium.js:1:3231720)
at executeCommands (http://192.168.100.95:18030/test/static/libs/Cesium/Cesium.js:1:3237516)
CesiumWidget.showErrorPanel @ Cesium.js:1
:18030/test/#/Map?userId=18:1 WebGL: CONTEXT_LOST_WEBGL: loseContext: context lost
I think webgl restrictions? You cannot open multiple cesium web pages at the same time Maybe
But When I try to open your online address more then 20 on this machine. https://sandcastle.cesium.com/standalone.html#c=bY9Pa8MwDMW/ivGpgyGz6+qGQq+FHQY7+aI6Wmuq2MFSUtJPvyS9jK26vaf3058RqxkT3aiancl0MweSNHTwtXqbYOOqDyUrpkw12JdtyPbVetGJqQnZrLVPXV+qmqHyBsApdT2jkrjTEK+kEEUWcIl69xv1bRpNandPNpnIKDJ3vgfmz3SnYBvv5vw/lAu2KZ8/RqqM0xK7vDXHhwkA3s3yOaml8Anrn8nzfxfVXt6dE8xtRFEmeBwIsXTujMxUJ/cD.A miracle happened,No error reported!!
So,Call the cesium app deployed in my environment for more than 20 times and an error will be reported,but if you open your online address more than 20 times, you will not report an error.
I will try not to use the Vue Framework ,but to use pure HTML to implement the basic create Cesium page for testing. In the meantime, I hope to get some comments from you!! ![]()
the bat Can open more pagestartOpenMultipleCesiumPage.zip (559 Bytes)
I will share it with the community if similar questions arise.
