Hello guys and thanks in advance for your help.
My code is very simple as below.
When I click and release the mouse left button for the first time after program start, I can not see “left up” console message.
But from the second time, I can see “left up” console message.
Is there anyone who can explain why?
Thanks
viewer = new Cesium.Viewer(‘cesiumContainer’);
var scene = viewer.scene;
var handler = new Cesium.ScreenSpaceEventHandler(scene.canvas);
handler.setInputAction(function(movement) {
console.log(“left down”);
var handler1 = new Cesium.ScreenSpaceEventHandler(scene.canvas);
handler1.setInputAction(function(movement) {
console.info(“mouse move”);
console.warn(“left up”);
handler1.destroy();
}, Cesium.ScreenSpaceEventType.LEFT_UP);
}, Cesium.ScreenSpaceEventType.LEFT_DOWN);
**3. Context. Why do you need to do this? We might know a better way to **
accomplish your goal.
I am making a polygon drawing tool.
After polygon is drawn, we need to modify the vertex of the polygon.
To do this, we select one vertex and drag and drop to the desired position.
Above code is used for this.
Cesium version 1.59.
windows 10
Chrome 75.0.3770.100
