Why showing place wrong inserting coordinate to entity position with Cesium.Cartesian3.fromDegrees
Coordinates of entity with entity position with Cesium.Cartesian3.fromDegrees(lat,long,height) from WGS84 show wrong place...
window.setInterval("flightradar('D-AEWS')",100);
var res4=0
var res5=0
var res6=0
var res7=0
var res8=0
var timer=0
    'use strict';
//Sandcastle_Begin
    infoBox : false,
    selectionIndicator : false,
    shadows : true,
    shouldAnimate : true,
    terrainProvider: Cesium.createWorldTerrain({requestWaterMask: true}),
    scene3DOnly: true,
    selectionIndicator: false,
    baseLayerPicker: false
var layers = viewer.scene.imageryLayers;
var mapOpenWeatherMaps = layers.addImageryProvider(new Cesium.createOpenStreetMapImageryProvider( {
        url: ‘http://tile.openweathermap.org/map/clouds_new’,
        fileExtension: ‘png’ + ‘?appid=d56085bd95e53422bbda70c0fea04ae0’
mapOpenWeatherMaps.opacity=0.2
var scene = viewer.scene;
    var positions= ;
        handler = new Cesium.ScreenSpaceEventHandler(scene.canvas);
        handler.setInputAction(function(dbClick){
}, Cesium.ScreenSpaceEventType.LEFT_DOUBLE_CLICK);
function flightradar(registration)
  { timer=timer+1
  if(timer>100)
      {var date= new Date()
      var res
      var url = 'http://data-live.flightradar24.com/zones/fcgi/feed.js?reg=!’+registration+’&_=’+date
      var doc= new XMLHttpRequest()
      doc.onreadystatechange = function(){
          if(doc.readyState == XMLHttpRequest.DONE){
              res=doc.responseText//JS.data(doc.responseText)
              var res1=res.split("[")
              var res2=res1[1]
              var res3=res2.split(",")
               res4=parseFloat(res3[1]) //latitude_value
               res5=parseFloat(res3[2]) // longitude_value
               res6=parseFloat(res3[3]) // track_value
              res7=parseFloat(res3[4])*0.3048 // altitude_value
              res8=parseFloat(res3[5]) // speed_value
              //console.log(res4+" “+res5+” “+res6+” “+res7+” "+res8)
      doc.open('GET', url, true)
      doc.send()
      timer=0
      window.print(res4+" "+res5+" "+res7)
      viewer.entities.removeAll();
var vit=res8
var track=res6
var lat=res4
var lon=res5
var radius = 6370640
var speed_ms=vit*0.51444
var distance=speed_ms*0.09
var δ = Number(distance) / radius; // angular distance in radians
var θ = Number(track)*Math.PI/180;
var φ1 = lat*Math.PI/180;
var λ1 = lon*Math.PI/180;
var sinφ1 = Math.sin(φ1), cosφ1 = Math.cos(φ1);
var sinδ = Math.sin(δ), cosδ = Math.cos(δ);
var sinθ = Math.sin(θ), cosθ = Math.cos(θ);
var sinφ2 = sinφ1*cosδ + cosφ1*sinδ*cosθ;
var φ2 = Math.asin(sinφ2);
var y = sinθ * sinδ * cosφ1;
var x = cosδ - sinφ1 * sinφ2;
var λ2 = λ1 + Math.atan2(y, x);
let newLat =φ2*180/Math.PI
let newLong= (λ2*180/Math.PI+540)%360-180
  res4=newLat
  res5=newLong
      var position = Cesium.Cartesian3.fromDegrees(res4, res5, res7);
      var heading = Cesium.Math.toRadians(res6);
      var pitch = 0;
      var roll = 0;
      var hpr = new Cesium.HeadingPitchRoll(heading, pitch, roll);
      var orientation = Cesium.Transforms.headingPitchRollQuaternion(position, hpr);
          position : position,
          orientation : orientation,
          model : {
              uri : '../../../../Apps/SampleData/models/CesiumAir/Cesium_Air.glb',
              minimumPixelSize : 128,
              maximumScale : 20000
//Sandcastle_End
    Sandcastle.finishedLoading();
following aircraft in 3d with flightradar api
cesium 1.51, win10/64, Qt 5.10.1 / 64 / MSVC2015 / WebView
Can you explain a little more? Where is the entity showing up on Cesium vs where do you expect it to show up? How far away is it from the correct position? Does the flight radar API return longitude latitude as well?
I think you might just be passing lat/long in the wrong order. See:
https://groups.google.com/d/msg/cesium-dev/aQbI1-NvzTQ/e0y30ucNBgAJ
