I have a 3D tileset set on top of the Cesium terrain. I am adding points and drawing a polyline between each pair with labels containing the distance, this mostly seems to be correct apart from some strange positioning that I’m seeing.
The point labels and line appear to be in the right place, but the height value of the points themselves seems to be off - the screenshots show the point labels on the 3D tileset and another shows the coloured points in the correct position, but the wrong height.
If I zoom out even further, the label that is meant to be positioned halfway between each pair of points is now underneath the terrain.
I am transforming the tileset itself on page load as it seems to be clashing with the terrain, so I am increasing the height by 8 to try and get it level with the terrain.
var cesiumTerrainProvider = Cesium.createWorldTerrain();
var ellipsoidTerrainProvider = new Cesium.EllipsoidTerrainProvider();
var entities = ;
var points = ;
var linePoints = ;
var distanceLabels = ;
var line;
animation: false,
baseLayerPicker: false,
terrainProvider: cesiumTerrainProvider,
infoBox: true,
scene3DOnly: true,
timeline: false
var scene = viewer.scene;
var handler = new Cesium.ScreenSpaceEventHandler(scene.canvas);
scene.globe.depthTestAgainstTerrain = true;
scene.logarithmicDepthBuffer = true;
var tileset = viewer.scene.primitives.add(new Cesium.Cesium3DTileset({
url: ‘/Scene/Production_1.json’,
ellipsoid: Cesium.Ellipsoid.UNIT_SPHERE
var heightOffset = 8;
tileset.readyPromise.then(function(tileset) {
// Position tileset
var boundingSphere = tileset.boundingSphere;
var cartographic = Cesium.Cartographic.fromCartesian(boundingSphere.center);
var surface = Cesium.Cartesian3.fromRadians(cartographic.longitude, cartographic.latitude, 0.0);
var offset = Cesium.Cartesian3.fromRadians(cartographic.longitude, cartographic.latitude, heightOffset);
var translation = Cesium.Cartesian3.subtract(offset, surface, new Cesium.Cartesian3());
tileset.modelMatrix = Cesium.Matrix4.fromTranslation(translation);
handler.setInputAction(function(click) {
var position = viewer.scene.pickPosition(click.position);
// there is a form step here but omitting it for brevity:
var data = {
position: position,
uuid: ‘point 1’,
description: ‘point 1’,
colour: ‘red’
addPoint(data);
toggleModal();
}, Cesium.ScreenSpaceEventType.LEFT_DOUBLE_CLICK);
function addPoint(data) {
var point = {
description: data.description,
position: data.position,
allowPicking: true,
point: {
disableDepthTestDistance: Number.POSITIVE_INFINITY,
heightReference: Cesium.HeightReference.RELATIVE_TO_GROUND,
show: true,
pixelSize: 10,
color: Cesium.Color[data.colour].withAlpha(0.5),
zIndex: 99
label: {
text: data.name,
font: ‘9pt monospace’,
style: Cesium.LabelStyle.FILL_AND_OUTLINE,
outlineWidth: 2,
verticalOrigin: Cesium.VerticalOrigin.BOTTOM,
pixelOffset: new Cesium.Cartesian2(0, -10)
var pointObject = new Cesium.ReferenceProperty(viewer.entities, data.uuid, [‘position’]);
linePoints.push(pointObject);
points.push(point);
entities.push(point);
viewer.entities.add(point);
// draw line with all points
drawLine();
function drawLine() {
// remove line
removeLine();
if (linePoints.length > 0) {
line = viewer.entities.add({
polyline: {
positions: new Cesium.PositionPropertyArray(linePoints),
width: 5,
material: new Cesium.PolylineOutlineMaterialProperty({
color: Cesium.Color.RED.withAlpha(0.5),
outlineColor: Cesium.Color.RED.withAlpha(0.5),
outlineWidth: 2.5
setTimeout(function() {
calculateDistance();
}, 500);
function calculateDistance() {
// console.log(‘calculate distance’);
if (linePoints.length > 1) {
// console.log(linePoints.length);
for (var i = 0; i < (linePoints.length - 1); i++) {
var start = linePoints[i]._targetEntity._position._value;
var end = linePoints[i + 1]._targetEntity._position._value;
var ellipsoid = scene.globe.ellipsoid;
var geodesic = new Cesium.EllipsoidGeodesic(ellipsoid.cartesianToCartographic(start), ellipsoid.cartesianToCartographic(end));
var midpoint = geodesic.interpolateUsingFraction(0.5, new Cesium.Cartographic());
var distance = Cesium.Cartesian3.distance(start, end).toFixed(2);
position: Cesium.Cartographic.toCartesian(midpoint),
label: {
show: true,
showBackground: true,
font: ‘12px monospace’,
horizontalOrigin: Cesium.HorizontalOrigin.LEFT,
verticalOrigin: Cesium.VerticalOrigin.CENTER,
pixelOffset: new Cesium.Cartesian2(-50, 0),
scale: 1.0,
text: distance + ’ metres’
distanceLabels.push(entity);
function removeLine() {
if (line) {
viewer.entities.remove(line);
removeDistanceLabels();
line = null;
function removeDistanceLabels() {
for (var i = 0; i < distanceLabels.length; i++) {
viewer.entities.remove(distanceLabels[i]);
distanceLabels = ;
Attempting to add points to a 3D tileset and be able to measure horizontal and vertical distances between them.
Cesium 1.62, OS X Mojave, Chrome.
