TerrainProvider and Position of Entities
I have a entity and use the position callback to get the position. Starting with ellipsoid after changing the terrainProvider the entity isn't displayed.
The code is from the forum:
var windowPosition = new Cesium.Cartesian2(viewer.container.clientWidth / 2, viewer.container.clientHeight / 2);
var pickPosition = viewer.camera.pickEllipsoid(windowPosition);
var position = pickPosition;
var positionCBP = function(){
  return position;
var svgEntityImage = svgDataDeclare + svgString;
myTarget = viewer.entities.add({
  name : 'Target on surface',
  position: new Cesium.CallbackProperty(positionCBP, false),
  billboard: {
    image: svgEntityImage
It would be good to see the entity independet of the choice of the terrainProvider.
1.40, windows7, chrome
Try using HeightReference.CLAMP_TO_GROUND for the heightReference to lock the height to the terrain surface.
name : ‘Target on surface’,
billboard: {
image: svgEntityImage,
heightReference : Cesium.HeightReference.CLAMP_TO_GROUND
Gabby
