Hi, happy new year
I meet a problem when I add some CylinderGeometry with Primitive API,
the geometry can be seen when the camera stays far away from the surface, like the first annex.
When I zoomIn, the geometry disappears and cutted by the horizon,
the part beyond horizon can be seen, and geometry below the horizon disappear, like the second annex.
I found a title here https://groups.google.com/forum/#!topic/cesium-dev/7ZDpbvjzhgY, which caused by disabling ANGLE,
what confused me is that the porblem appears just in Mac no matter what browser I use, but runs well in windows system.
here is my function to render the geometry
//the entities come from a promise
renderHistogram: function(entities, config, cid){
var color = Cesium.Color.fromCssColorString(config.markerColor).withAlpha(config.markerOpacity);
var len = entities.length;
var instances = [];
for(var i = 0; i < len; i++){
var geometry = new Cesium.CylinderGeometry({
length : 50000,
topRadius : 10000,
bottomRadius : 10000,
slices: slices,
vertexFormat : Cesium.PerInstanceColorAppearance.VERTEX_FORMAT
entities[i].billboard = undefined; //todo: why there is a billboard at the very beginning
var position = entities[i].position._value;
var instance = new Cesium.GeometryInstance({
geometry: geometry,
modelMatrix: Cesium.Matrix4.multiplyByTranslation(
Cesium.Transforms.eastNorthUpToFixedFrame(Cesium.Cartesian3.fromElements(position["x"], position["y"], position["z"],new Cesium.Cartesian3())),
new Cesium.Cartesian3(0.0,0.0, 0.0),new Cesium.Matrix4()
attributes: {
color : Cesium.ColorGeometryInstanceAttribute.fromColor(color),
distanceDisplayCondition : new Cesium.DistanceDisplayConditionGeometryInstanceAttribute(10.0, 50000000.0)
instances.push(instance)
primitive = new Cesium.Primitive({
geometryInstances: instances,
appearance: new Cesium.PerInstanceColorAppearance({
closed : true,
translucent: true,
flat: false,
faceForward: false
allow3DOnly: true,
vertexCacheOptimize: true,
allowPicking: true,
releaseGeometryInstances: false,
cull:false
this.globe.scene.primitives.add(primitive);
anyone could help?
