When trying to use CesiumForUnreal 2.3.0 in my UE5.3 project, the following error occurred
UE_5.3\Engine\Source\Runtime\UMG\Public\FieldNotification\FieldNotificationDeclaration.h(15): warning C4996: 'FieldNotificationDeclarationHeaderDeprecatedWarning': Including FieldNotification/FieldNotificationDeclaration.h is deprecated. The location of has changed. Please include FieldNotificationDeclaration.h instead and add the module FieldNotification to your .build.cs Please update your code to the new API before upgrading to the next release, otherwise your project will no longer compile.
UE_5.3\Engine\Source\Runtime\UMG\Public\Components\Widget.h(222): error C4042: 'unnamed-parameter': has bad storage class
UE_5.3\Engine\Source\Runtime\UMG\Public\Components\Widget.h(223): error C3646: 'UE_FIELD_NOTIFICATION_DECLARE_FIELD': unknown override specifier
UE_5.3\Engine\Source\Runtime\UMG\Public\Components\Widget.h(223): error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
I did not set DefaultBuildSettings in target.cs in my project.
I was able to build without error by adding the following to CeciumRuntime.Build.cs
DefaultBuildSettings = BuildSettingsVersion.V4;.
I am not familiar with BuildSettingsVersion, but it seems to me that if this setting is included, it would be good as it would allow you to build without depending on the project settings, what do you think?
