I’m using this code snippet that I found on the AGI github, but it only renders the 1st weather image. Am I doing something wrong, should I implement my own timer and do something to update/re-render the provider?
function dataCallback(interval, index) {
var time;
if (index === 0) { // leading
time = Cesium.JulianDate.toIso8601(interval.stop);
} else {
time = Cesium.JulianDate.toIso8601(interval.start);
return {
Time: time
var times = Cesium.TimeIntervalCollection.fromIso8601({
iso8601: ‘2017-06-30/2018-05-21/P1D’,
leadingInterval: true,
trailingInterval: true,
isStopIncluded: false, // We want stop time to be part of the trailing interval
dataCallback: dataCallback
var imageryLayers = viewer.imageryLayers;
var provider = new Cesium.WebMapServiceImageryProvider({
url: "http://mesonet.agron.iastate.edu/cgi-bin/wms/nexrad/n0q-t.cgi?",
layers: “nexrad-n0q-wmst”,
parameters: {
format: ‘image/png’,
transparent: ‘true’
times: times,
clock: viewer.clock
imageryLayers.addImageryProvider(provider);
provider.readyPromise
.then(function() {
var start = Cesium.JulianDate.fromIso8601(‘2017-06-30’);
var end = Cesium.JulianDate.fromIso8601(‘2018-05-21’);
viewer.timeline.zoomTo(start, end);
var clock = viewer.clock;
clock.startTime = start;
clock.endTime = end;
clock.currentTime = start;
clock.clockRange = Cesium.ClockRange.LOOP_STOP;
clock.multiplier = 10; // sped this up once everything rendered
My end goal is to use the geomet wms from Environment Canada who offer a composite all North America, which may be a long shot since they may not even offer WMS-T.
I’m using 1.45 on firefox.
Thanks!,
Ian
