Hey,
I’m trying to work with cesium-native repo for reading and getting data from DTED files.
I didn’t manage to find the functions to do so.
Is it even possible? Am I trying to do something impossible or I’m just missing something?
is the cesium-native just a base for the other APIs or is it a usable library?
Thanks for the help!
https://chat.openai.com/?model=gpt-4-code-interpreter
1. Setting up cesium-native
Before we can work with DTED data in cesium-native, we need to ensure cesium-native is set up correctly:
- Clone the Repository:
bashCopy code
git clone https://github.com/CesiumGS/cesium-native.git
- Build the Project: Navigate to the cloned directory and create a build directory:
bashCopy code
mkdir build && cd build
Configure and build the project with CMake:
bashCopy code
cmake ..
make -j4 # Adjust '4' to the number of CPU cores you want to use for the build.
2. Integrating a DTED Reader with cesium-native
cesium-native doesn’t have built-in support for DTED. You’d need to either:
- Use an existing DTED reading library.
- Write your own DTED parser.
For the sake of this guide, let’s assume you’re going with the first option.
Find a DTED Reading Library: There are several open-source libraries that can read DTED files. One such option is GDAL. Once you’ve chosen a library, integrate it into your cesium-native project. This might involve including the library’s headers, linking against its binaries, and adding any necessary initialization code.
3. Reading DTED Data
With your DTED reader integrated:
- Load the DTED File: Use the DTED reading library to open and read your DTED file.
- Extract Elevation Data: The primary data of interest in a DTED file is its elevation data. Extract this data into a format that you can work with in
cesium-native. This will typically be a 2D array of elevation values.
4. Convert DTED Data to Desired Output
Depending on your needs, you might want to:
- Convert to Quantized Mesh: If you’re aiming to display the terrain in CesiumJS, you might want to convert the elevation data to the Quantized Mesh format, which is optimized for CesiumJS rendering.
- Generate 3D Tiles: Another option for CesiumJS is to convert the DTED data into 3D Tiles, which is a format optimized for streaming and rendering 3D data.
5. Displaying the Data in CesiumJS
Once you’ve processed the DTED data:
- Serve the Data: If you’ve converted the data to Quantized Mesh or 3D Tiles, you’ll need to serve it from a web server or a specialized tile server.
- Load in CesiumJS: In your CesiumJS application, add a new terrain provider pointing to your served DTED data.
Caveats & Considerations
- Performance: DTED files can be large, especially if you’re working with high-resolution data. Ensure that your processing pipeline is optimized, especially if you’re planning to process many files.
- Accuracy: Ensure that the DTED reading library you choose is accurate and can handle any quirks or variations in the DTED format.
- Licensing: Some DTED data might come with licensing restrictions. Ensure that you have the necessary permissions to use and distribute the data.
This is a high-level overview of the process. Each step can be quite involved, especially when it comes to integrating a new library with cesium-native or converting the DTED data into another format. If you run into specific issues or have questions about a particular step, please let me know!
When working with DTED data, the most recommended and widely-used library is GDAL (Geospatial Data Abstraction Library). GDAL provides the ability to read, write, and transform a wide variety of raster and vector geospatial datasets, including DTED.
Here’s a step-by-step guide to using GDAL to read DTED data:
1. Installing GDAL
Using a Package Manager: If you’re on a Linux system, you can often install GDAL using your package manager:
bashCopy code
# For Ubuntu/Debian:
sudo apt-get install libgdal-dev
# For Fedora:
sudo dnf install gdal-devel
# For CentOS:
sudo yum install gdal-devel
From Source: You can also download GDAL’s source and compile it yourself.
2. Integrating GDAL with cesium-native
Once you’ve installed GDAL, you’ll need to make sure your project knows where to find its headers and libraries:
- Add the GDAL include path to your project’s include directories.
- Link your project against the GDAL library.
3. Reading DTED Data with GDAL
Here’s a basic code snippet to read a DTED file using GDAL:
cppCopy code
#include "gdal_priv.h"
int main() {
GDALAllRegister(); // Register all available file formats
GDALDataset *dataset = (GDALDataset*) GDALOpen("path_to_your_dted_file.dt0", GA_ReadOnly);
if(dataset == nullptr) {
// Handle error
return 1;
// Get the elevation band (usually the first band in a DTED file)
GDALRasterBand *band = dataset->GetRasterBand(1);
int width = band->GetXSize();
int height = band->GetYSize();
float *elevations = new float[width * height];
band->RasterIO(GF_Read, 0, 0, width, height, elevations, width, height, GDT_Float32, 0, 0);
// At this point, 'elevations' contains the elevation data from the DTED file.
// Do something with the data...
delete[] elevations;
GDALClose(dataset);
return 0;
This code opens a DTED file, reads its elevation data into an array, and then closes the file. You can then use this elevation data as needed in your application.
4. Additional Considerations
- Error Handling: The above code is a basic example and doesn’t include thorough error handling. In a real-world scenario, you’d want to check for errors at every step and handle them appropriately.
- Coordinate Systems: DTED data is typically in a geographic coordinate system (latitude and longitude). Depending on your needs, you might need to reproject the data to a different coordinate system.
- Dependencies: Ensure you’ve linked against all required GDAL dependencies when building your project.
This should give you a starting point to work with DTED data in your cesium-native project using GDAL. If you have further questions or run into issues, let me know!
Step 4, a simple matter of programming… not. cesium-native does not write Quantized Mesh. There is a writer for 3D Tiles, but I hesitate to say that you can generate 3D Tiles as such.
I am having a Windows application for Telecom domain which is written in C++ using Visual Studio and now the requirement has raised to implement 3D Maps in the application so I want guidance to know that which API of Cesium will best fit in this case and how can I get a manual guide to use that API in my C++ application ?
