Zoom map to location
I use this demo from the Sandcastle here:
How can I make it so that the location of the browser is transmitted and so that the map zooms to the location?
Are there any examples of this?
Unfortunately I haven’t found one.
I thank you in advance.
Many greetings
Hi @Mr.Lion ,
Here is a Sandcastle example: click me
The example uses the Geolocation API to get coordinates of your browser/device (if the user allows it, and the site is https) and methods of the Cesium “camera”.
Best, Lennart
Hi Lennart,
thank you for the answer and for the example.
Sorry that I answer very late. I was sick in bed for a few days, almost a week, and unfortunately couldn’t answer any earlier.
The example on Sandcastle helped me a lot and was able to adopt it so far.
However, I have a few additions with which I have unfortunately not been successful and would be very happy if I could get help.
I did it that way, when I click on the “Show Location” button, the camera flies there. This works so far, but if I set the angle of the camera by -45 degrees, then the location is no longer in the view of the camera. It’s postponed. I can fix that manually by setting the (Latitude - 0.100), but normally the script would have to do this itself, so the more precise calculation now, or not?
I have set a PIN for the location with “Cesium.pinBuilder()”. To better illustrate the location. From this I can see that the location is definitely shifted at “viewer.camera.flyTo()”. How can I improve this?
I still have the problem that when I scroll into it, the pin disappears in the background. I have a problem with that and don’t know how to fix it.
I also have a question about the location.
With the Geolocation API I get the “longitude” and “langitude” great, but how do I get the height of the location?
Couldn’t I have this calculated using the “langitude” and “longitude”? Unfortunately, I couldn’t find a solution on the Internet.
Here is the code:
From line 378 I commented out an attempt. If I try it out like in the comment, then the globe turns crazy 200 times around until it has reached the location.
Here I couldn’t define the height either :frowning:
Here I have another function as I set the pin:
Here the pin is at 10,000. But when I scroll through it now, the pin disappears more and more in the background:
Shouldn’t the height be adjusted automatically when scrolling, or not?
I ask for help on these few individual points.
Thank you in advance.
Many greetings
because of depthTest,
you can use this for all objects
viewer.scene.globe.depthTestAgainstTerrain = true;
or I see you add bilboard so bilboard has this property : disableDepthTestDistance
https://cesium.com/learn/cesiumjs/ref-doc/Billboard.html?classFilter=bill#disableDepthTestDistance
thank you for the hints.
I’m already using this and it’s still buggy.
According to the documentation, I don’t know what number value has to come in.
I played around with some fictional numbers but the bilboard is still flawed as described above.
When I scroll in or out, the bilboard sinks until it is completely gone. That also happens when I turn the globe.
