Zoom to coordinates while keeping a certain height
I wrote a code in order to zoom to a certain point. The problem is it goes underground and I need to manually zoom out, while I want to do it automatically (by setting altitude, something like that).
var e = viewer.entities.add({
position : Cesium.Cartesian3.fromDegrees(10.649839138, 40.123856495),
point : {
verticalOrigin : Cesium.VerticalOrigin.BOTTOM
viewer.zoomTo(e);
I need to zoom to a point without going underground.
CesiumJS 1.60
Windows 7
Mozilla Firefox 68.0.2
You can use the viewer.flyTo method (https://cesiumjs.org/Cesium/Build/Documentation/Viewer.html?classFilter=viewer#flyTo) which takes an entity, and a set of options, so you can control the height or angle offset from what the camera is flying to.
The zoomTo method also has a similar offset option (see https://cesiumjs.org/Cesium/Build/Documentation/Viewer.html?classFilter=viewer#zoomTo).
What kind of project are you working on?
I solved my problem using the flyTo() method, thank you very much!
useful…
