Is it possible to zoom to a primitive or a primitive collection?
Greetings
Greetings
There isn’t a built-in way to zoom to a primitive the way you can zoom to an entity. I would recommend using the Entity API for creating your primtiives.
However, if you have a reason you don’t want to use entities, you can use the Camera.flyTo method to fly the camera to a certain position or a rectangle. If you have the positions for a polyline or polygon on the globe, you can use Rectangle.fromCartesianArray to create a rectangle that encloses these points.
Depending on what your data is, you may also want to consider finding a BoundingSphere for the primitive and using Camera.flyToBoundingSphere to zoom to it.
Hannah
I am trying to zoom to a gltf model which is loaded dynamically. No success so far.
Can you paste a code example showing what you’re trying to do?
-Hannah
Sure.
for (var i = 0; i < building_names.length; i++) {
geoloc=buildings.getJsonByBuildingName(building_names[i]);
// add to cesium
var gltf_json = JSON.parse(gltfs[i]);
var origin = Cesium.Cartesian3.fromDegrees(geoloc.longitude,geoloc.latitude,0);
var matrix = Cesium.Transforms.eastNorthUpToFixedFrame(origin);
var model = scene.primitives.add(new Cesium.Model({
gltf : gltf_json,
modelMatrix : matrix
