After upgrading nothing but the version to 1.63 there is now a globe within a globe in my app. Removing viewer.scene.globe.enableLighting = true; fixes the issue.
Go to sandcastle and rand the following:
Was using 1.62 and everything was working ok. Upgrading to 1.63 caused the attached screenshot.
Wow, thanks for reporting this. This is definitely a bug. It’s caused by I think an inconsistent pixel ratio. This PR changed it so that the shaders would use the correct scale based on the resolution: https://github.com/AnalyticalGraphicsInc/cesium/pull/8318
But I think it might have missed something. I’m going to see if I can put together a quick fix for this. In the mean time you can work around it in your application by setting:
