From the demo website (https://cesiumjs.org/ ) I can see 3D visualization of mountains.
When I run the code locally, or on my server, 3D visualization is not present anymore.
I didn’t modify the code from the official release.
I need 3D visualization of mountains.
CesiumJS 1.60, Windows 7, Firefox 68.0.1
Are there any messages in the developer console (F12)?
Does the Cesium Viewer app work?
omar
August 12, 2019, 4:07pm
#3
Cesium World Terrain is not enabled by default. You can turn it on by clicking on the base layer widget (top right, next to the question mark button) and select “Cesium World Terrain” at the bottom. You can also turn it on programmatically in your code, see adding Cesium World Terrain in the getting started:
https://cesium.com/docs/tutorials/getting-started/#adding-cesium-world-terrain
Thank you, that was the problem.
Now the mountains are on top of my KML points (which are now invisible, I can see them by going under the mountains).
I tried changing the Z coordinate but nothing really changes.
Any ideas? Thanks.
omar
August 13, 2019, 9:21pm
#5
There is a clampToGround option you can set to true when you’re loading in a KmlDataSource:
https://cesiumjs.org/Cesium/Build/Documentation/KmlDataSource.html?classFilter=KMLDa#.load
