I am implementing a measurement system for 3D point clouds. After some research, I’m trying to decide the best approach.
There isn’t really a single piece of code that describes my problem. More in the following section.
Take a look at Potree measurements: http://potree.org/potree/examples/measurements.html
I’m trying to implement the same functionality in Cesium. Requirements are:
Drawing of points, polylines and polygons on the point cloud
Smooth updates when changing positions quickly (mouse move)
Constant lines and points sizes
Always drawn on top of the point cloud (depth fail)
Use documented Cesium API
I’ve done some research, and came to the following conclusions: -
Drawing an entity with dynamic positions (via CallbackProperty) doesn’t fulfil requirement #4 due to an open issue.
Drawing an entity with static positions and changing them on mouse move doesn’t fulfil requirement #2: the shape flickers
Drawing a primitive using PolylineGeometry (removing and re-adding it on mouse move) doesn’t fulfil requirement #3: the line “flattens” when viewed from an angle, as it’s a 3D shape
Drawing a primitive using SimplePolylineGeometry (removing and re-adding it on mouse move) doesn’t fulfil requirement #2: the shape flickers
Drawing a primitive using PolylineVolumeGeometry (removing and re-adding it on mouse move) doesn’t fulfil requirement #3: the volume is set in meters, and thus zooming in and out makes the shape change its size
Drawing a primitive using SimplePolylineGeometry (removing and re-adding it on mouse move, and calling Primitive.update manually to prevent flickering) doesn’t fulfil requirement #5 , as update should not be called manually. An example of this is shown here , you can try drawing on the dark globe in the middle of the screen.
Drawing an entity with dynamic positions (via CallbackProperty) and overriding PolylineCollection.update manually doesn’t fulfil requirement #5, as it requires overwriting Cesium code in runtime.
I am currently leaning towards implementing using either 6 or 7 above. I would appreciate your feedback.
1.61, Mac Mojave, Chrome latest.
