Previously we have been trimming our 3D-tiles in pre-production, but this is not always practical. We are attempting to implement cesium clipping planes to allow us to define areas to hide but have not been having much luck. Our ultimate aim is to draw a polygon, convert each straight edge into a vertical clipping plane and exclude from display that texture that falls outside the planes. Currently we are just trying to get clipping planes of any definition to work our 3d-tile dataset and regardless of what we try there is zero effect on the 3d-tiles. Below is an example… any help would be much appreciated
tileset = viewer.scene.primitives.add(new Cesium.Cesium3DTileset({
url : tile_url,
clippingPlanes : new Cesium.ClippingPlaneCollection({
planes : [
new Cesium.Plane(new Cesium.Cartesian3(1.0, 0.0, 0.0), 0),
new Cesium.Plane(new Cesium.Cartesian3(-1.0, 0.0, 0.0), 0),
new Cesium.Plane(new Cesium.Cartesian3(0.0, 1.0, 0.0), 0),
new Cesium.Plane(new Cesium.Cartesian3(0.0, -1.0, 0.0), 0),
new Cesium.Plane(new Cesium.Cartesian3(0.0, 0.0, -1.0), 0)
unionClippingRegions : true
tileset.debugShowBoundingVolume = viewModel.debugBoundingVolumesEnabled;
return tileset.readyPromise.then(function() {
let boundingSphere = tileset.boundingSphere;
let radius = boundingSphere.radius;
// viewer.zoomTo(tileset, new Cesium.HeadingPitchRange(0.5, -0.2, radius * 4.0));
tileset.clippingPlanes.modelMatrix = Cesium.Transforms.eastNorthUpToFixedFrame(boundingSphere.center);
viewer.camera.viewBoundingSphere(boundingSphere, new Cesium.HeadingPitchRange(0.0, -0.5, boundingSphere.radius * 2));
viewer.camera.lookAtTransform(Cesium.Matrix4.IDENTITY);
for (let i = 0; i < clippingPlanes.length; ++i) {
let plane = clippingPlanes[i];
let planeEntity = viewer.entities.add({
position : boundingSphere.center,
plane : {
dimensions : new Cesium.Cartesian2(radius 2.5, radius 2.5),
material : Cesium.Color.WHITE.withAlpha(0.1),
plane : new Cesium.CallbackProperty(createPlaneUpdateFunction(plane, tileset.modelMatrix), false),
outline : true,
outlineColor : Cesium.Color.WHITE
planeEntities.push(planeEntity);
return tileset;
}).otherwise(function(error) {
console.log(error);
1.55
