var dig_point = [
new Cesium.Cartesian3.fromDegrees(20.24418855999141, 63.82015459978235),
new Cesium.Cartesian3.fromDegrees(20.25139109125409, 63.818916542464265),
new Cesium.Cartesian3.fromDegrees(20.250973969629612, 63.814013746004946),
new Cesium.Cartesian3.fromDegrees(20.23750570105997, 63.81444392633881)
var clippingPlanes = [];
var pointsLength = dig_point.length;
for (var i = 0; i < pointsLength; ++i) {
var nextIndex = (i + 1) % pointsLength;
var midpoint = Cesium.Cartesian3.add(dig_point[i], dig_point[nextIndex], new Cesium.Cartesian3());
midpoint = Cesium.Cartesian3.multiplyByScalar(midpoint, 0.5, midpoint);
var up = Cesium.Cartesian3.normalize(midpoint, new Cesium.Cartesian3());
var right = Cesium.Cartesian3.subtract(dig_point[nextIndex], midpoint, new Cesium.Cartesian3());
right = Cesium.Cartesian3.normalize(right, right);
var normal = Cesium.Cartesian3.cross(right, up, new Cesium.Cartesian3());
normal = Cesium.Cartesian3.normalize(normal, normal);
if (!false) { normal = Cesium.Cartesian3.multiplyByScalar(normal, -1, normal); }
var plane = new Cesium.Plane.fromPointNormal(midpoint, normal);
var clippingPlane = new Cesium.ClippingPlane.fromPlane(plane);
clippingPlanes.push(clippingPlane);
var tileset = viewer.scene.primitives.add(
new Cesium.Cesium3DTileset({
url: "../Tileset/Stadsmodell/tileset.json",
maximumScreenSpaceError: 2
tileset.readyPromise.then(function () {
tileset.clippingPlanes = new Cesium.ClippingPlaneCollection({
planes: clippingPlanes,
modelMatrix: Cesium.Matrix4.inverse(tileset.root.computedTransform, new Cesium.Matrix4())
}).otherwise(function (error) {
console.log(error);
Apologies for the delayed response. Is it possible to upload the tileset.json that you’re using, so I may experiment with it on my own machine? Alternatively, you can give me the asset ID and I can download it on my own.
Thank you for the reply. With ion resources it works perfectly fine. But when hosting myself (not as an ion resource) as cesium tiles exported from Metashape I can’t make it work.
I don’t have enough storage on ion to upload it. It’s almost 100gb…
When you say you have tried this “with ion resources,” can you confirm that you mean resources that are different from the tileset.json you first mentioned?
Above example has same code but with an resource from ion. Works fine. Problem is when exporting the tileset from Metashape like in this example: https://testkartor.umea.se/3D/test/
For 3D Tiles, the root tile’s transform is used to position the clipping planes. If a transform is not defined, the root tile’s Cesium3DTile#boundingSphere is used instead.
It’s possible the tileset you exported from Metashape doesn’t have a tile transform, though we would have to look at the tileset.json to confirm. I would experiment with one clipping plane first and ensure that it is positioned correctly before continuing to add more.
