3d-tiles validation
I would like to validate a 3d-tile sample with https://github.com/AnalyticalGraphicsInc/3d-tiles-tools/tree/master/validator
**when I run the command **node ./bin/3d-tiles-validator.js ./specs/data/Tileset/ nothing happend, no output, …
Do I miss someting ?
**newest - but I think the validator uses 1.39 resp. 1.55 **
I think it is not a problem of the validator - can you explain how to use the tool or is there another tool where I can validate a 3dtiles dataset ?
We don’t currently maintain a 3D Tiles validator, although we’d like to have one eventually. That branch is an experimental tool that was never officially released.
How are you creating your 3D Tiles? Is it exported from another software or are you building your own 3D Tiles generator? Are you having any issues with it?
How Omar,
i generated the 3d-tile by my own and got an error from CesiumJs during read - but this doesn’t help very much.
Rüdiger
Have you tried created your 3D Tiles with Cesium ion (https://cesium.com/ion/) ? You can upload your source data there and get a 3D Tileset.
Otherwise, have you tried using the 3D Tiles inspector? That provides some debug info that might help: https://sandcastle.cesium.com/index.html?src=3D%20Tiles%20Inspector.html
If you’re using the unminified version of CesiumJS it should make it easier to see where the error is coming from.
