About ImageMaterialProperty depth problem
how are you all~
As the title says, i have a problem.
I’m building a road on cesium these days, builing a road sign.
i’m using the wall of entity. It is as follows.
Looks good. be fit for my purpose.
i used a circular .png image file with alpha channel at this time. and then write a code like blow
front side is good. but problem is… turning back side like blow.
As you can see, there is a problem with depth.
is there any advice on this situation?
depth_troble
on the other hand, there is no problem if transparent = false .
depth_troble2
Any help is appreciated.
Hi, It would be great if you create a sandcastle example to help you on solving issue.
  • Regards
