About streaming and rendering of terrain
Hi
I have three problems.
Problem 1:
I try to show the geojson data on terrain,so I add STK World Terrain meshes,
when I zoom in and zoom out , the view is below
https://drive.google.com/open?id=0BzSg1YTd_o3Ba3d1YkVGX0xrSHJmdDRpREluSnNqTE1icmN3
is it a problem for streaming terrain?
How to fix it?
Problem 2:
when i view taipei city after add STK World Terrain meshes,that place is so strange.
How to fix it?
Problem 3:
About terrain
can I use my tif file, if it is so bad after terrain ?
How to do?
thank you!
persimon...@gmail.com於 2016年7月22日星期五 UTC+8下午3時22分57秒寫道:
Hi
Problem 1:
https://drive.google.com/open?id=0BzSg1YTd_o3BRFNEV2kxU0Zkb3FzT1REa3BpNFRBYmxlLXc4
https://drive.google.com/open?id=0BzSg1YTd_o3BV2lKTS14bVdfVUNLTE5ILV9DTExyS2pHZi1n
https://drive.google.com/open?id=0BzSg1YTd_o3BX3ZXWWVRSHI0U0M5Y1UzWDA4eEcxdEF0Si00
How to fix it?
Problem 2:
How to fix it?
Problem 3:
About terrain
How to do?
thank you!
code below
      var viewer = new Cesium.Viewer('cesiumContainer', {});
            var terrainSamplePositions = ;
            var promise = dataSource_r600_geojson.load('/SubareaGrid.geojson');
            promise.then(function (dataSource2) {
                viewer.dataSources.add(dataSource2);
                viewer.zoomTo(dataSource2);
        var colorHash = {};
                for (var i = 0; i < entities2.length; i++) {
                    var entity = entities2[i];
                    var name = entity.properties.GRID_CODE;//依CLASS
                    if(name==1){
                        entity.polygon.material = new Cesium.Color(0,1,0,0.8);
                        entity.polygon.outline = false;
                    if(name==2){
                        entity.polygon.material = new Cesium.Color(0,0,1,0.8);
                    if(name==3){
                        entity.polygon.material = new Cesium.Color(1,1,0,0.8);
                    if(name==4){
                        entity.polygon.material = new Cesium.Color(1,0,1,0.8);
                    if(name==5){
                        entity.polygon.material = new Cesium.Color(1,0,0,0.8);
                    // TODO: More sanity checking for undefined values etc.
                    var position = entity.polygon.hierarchy.getValue().positions[0];
                    terrainSamplePositions.push(Cesium.Cartographic.fromCartesian(position));
                // Asking for terrain heights is asynchronous, because the answer may
                // reside on the terrain server.
                Cesium.when(Cesium.sampleTerrain(viewer.terrainProvider, 12, terrainSamplePositions), function () {
                        var terrainHeight = terrainSamplePositions[i].height;
                        //test 2
                        if(name==1){
                            // The bottom of the building sits on the terrain.
                            entity.polygon.height = 0.1;//
                            // The top of the building adds the building height to the terrain height.
                            entity.polygon.extrudedHeight = 0;//拔高
                        if(name==2){
                            entity.polygon.height = terrainHeight+1;
                        if(name==3){
                            entity.polygon.height = terrainHeight+2;
                        if(name==4){
                            entity.polygon.height = terrainHeight+3;
                        if(name==5){
                            entity.polygon.height = terrainHeight+4;
the SubareaGrid.geojson as below
https://drive.google.com/open?id=0BzSg1YTd_o3BMXFRaUZKYkEyT1U
I solved my problem,just use setTimeout.
through https://github.com/AnalyticalGraphicsInc/cesium/issues/3411
