hi , do you have “CesiumWebMapTileServiceRasterOverlay” example?
i config such baseUrl, but it can’t work.
Hi @beyondlei99, welcome to the community!
The base URL is usually the URL without any parameters. Try removing the ? and everything after it.
If you’d like a working example, you can copy the parameters over from the CesiumJS Sandcastle here. This is the “USGS Shaded Relief (via WMTS)” example:
new Cesium.WebMapTileServiceImageryProvider({
url:
"https://basemap.nationalmap.gov/arcgis/rest/services/USGSShadedReliefOnly/MapServer/WMTS",
layer: "USGSShadedReliefOnly",
style: "default",
format: "image/jpeg",
tileMatrixSetID: "default028mm",
maximumLevel: 19,
credit: "U. S. Geological Survey",
