How to use these two scripts to complete the loading of these two services, there is an online service address can be tested? How to fill out the fields in these two scripts
Hi @jh007,
Just want to clarify – are you asking for examples of WMS or WMTS datasets? You can check out this WMS example in Sandcastle, and the WMTS imagery in this Sandcastle (USGS Shaded Relief). They will load in Cesium for Unity with similar parameters.
If I’ve misunderstood your question, though, please let me know.
Hi @jh007,
I apologize for the confusion – it looks like that WMS dataset is no longer accessible. I’ll see if I can find another WMS example.
In the mean time, I’m not sure why the WMTS layer wouldn’t be working for you. I was able to make it display successfully like so:
Can you please confirm that:
- You have filled out the parameters the same way as they appear in this image.
- You have attached the imagery component to a Cesium3DTileset.
Thank you!
Hi @jh007,
Thanks for your patience. We have a working WMS example now:
Base URL: https://services.ga.gov.au/gis/services/NM_Hydrology_and_Marine_Points/MapServer/WMSServer
Layer: Bores
You can see the data over Australia like so:
Regrading your WMTS, you just need to map the parameters of your WMTS service to those in Unity. I’m not sure I can advise because those really depend on your setup. From a glance it looks like that localhost URL is your Base URL, and you need to fill in the Style + Tile matrix Set ID + Format with the correct parameters.
Maybe other community members who have set up an WMTS service before can advise?
这个解决了吗?我用geoserver部署cesiumforunity也出不来会报错404,但是ue可以
@dwbcxy886, we believe WMS is working fine in Unity. If it’s not working for you, please start a new thread and share the details of your problem.
谢谢回复,我知道为啥404了,因为unity中tileMatrixSetLabelPrefix这个值通过ESGB:4326:传递是空值,我手动依次传递列表形式52个“ESGB:4326:0”就正常。
I’m not sure I completely understand, but good to hear you got it working!
