Add an offset from trackedEntity?
Is there a way to add an offset for the camera when it’s following a trackedEntity? (for example, if I want the camera to be farther away from the object than the default or if I want it to look at the object from an angle)
Or do I have to set that relative value on every clock tick?
I used
entity.viewFrom = new Cesium.Cartesian3(0, 0, someHeight);
to get a top-down view, but I am not sure if that is the “right” way. I reset viewFrom when I un-track the entity.
Willem
Thanks, Willem!
