Set trackedEntity x/y offset?
By default, if you assign an Entity to trackedEntity, the camera will lock into view it in the horizontal and vertical center of screen.
Is there a way to set an offset for that locked position? so that it’ll lock to some x/y offset?
Example, instead of having the entity in the center, have the entity in horizontal center, but only 1/3 up from bottom?
Hi @poncho524,
Thank you for your questions! I do not believe that the trackedEntity object allows you to specify a camera offset. However, one potential workaround would be to use the Camera object API to meet your needs.
https://cesium.com/learn/cesiumjs/ref-doc/Camera.html?classFilter=camera
-Sam
