I am working on cesium but now got stuck because i want to show name or description in the center of polygon but not able to do it.Please post your ideas for this.
thanks in advance.
thanks in advance.
Below is a complete example that should do what you want that you can paste into Sandcastle. If you already know the center point, you can simplify the code further. I would also recommend checking out the Visualizing Spatial Data tutorial if you haven’t already.
var positions = Cesium.Cartesian3.fromDegreesArray([-115.0, 37.0,
-115.0, 32.0,
-107.0, 33.0,
-102.0, 31.0,
-102.0, 35.0]);
var bs = Cesium.BoundingSphere.fromPoints(positions);
var center = Cesium.Ellipsoid.WGS84.scaleToGeodeticSurface(bs.center);
var redPolygon = viewer.entities.add({
position : center,
label : {
text : “I’m in the center!”
polygon : {
hierarchy : positions,
material : Cesium.Color.RED.withAlpha(0.5)
