I am working on cesium but now got stuck because i want to show name or description in the center of polygon but not able to do it.Please post your ideas for this.
thanks in advance.
thanks in advance.
You can add a label as a separate primitive. You will have to compute the position at the center of the polygon yourself though.
Here’s an exampe:
var polygon = viewer.entities.add({
polygon : {
hierarchy : Cesium.Cartesian3.fromDegreesArray([-115.0, 38.0,
-115.0, 32.0,
-105.0, 32.0,
-105.0, 37.0]),
material : Cesium.Color.RED
var label = viewer.entities.add({
label: {
text: polygon.name,
verticalOrigin: Cesium.VerticalOrigin.BOTTOM,
horizontalOrigin: Cesium.HorizontalOrigin.CENTER,
eyeOffset: new Cesium.Cartesian3(0,0,-200)
position: Cesium.Cartesian3.fromDegrees(-110, 35)
The horizontalOrigin property centers the label over the point, and the verticalOrigin and eyeOffset properties help prevent the label from going under the polygon.
Hannah
