Adding Cesium for Omniverse to Omniverse Applications
Hello Cesium Team,
Whenever try to add Cesium to Omniverse Applications, I am getting the following error when build app step.
[Error] [omni.ext.plugin] One of dependencies, extension ‘cesium.usd.plugins-0.6.0’ is untrusted. Install it manually from the extension manager UI and try again.
The document link I followed is below.
Hi @sahincan. Which application are you attempting to add this to, or do you have a custom application example?
The Omniverse ecosystem is undergoing some significant changes, including deprecation of various apps such as the one in the linked tutorial. There are also different versions of Kit in use, which means some apps may not be supported by Cesium for Omniverse.
We’re currently in the process of reviewing our tutorials to cater for these upgrades, so any additional information you can provide on your use case could assist us in producing more relevant documentation.
